Deletes a server from an Automation Edge remote VXLAN network identifier (VNI)-device database.
| database | Deletes server from a remote VNI-database. |
| database_name | Deletes server from the named database. |
| delete | Deletes a server from the database. |
| server | Deletes a from to the database. |
| host_name | Specifies the hostname of the server to delete from the database. |
| ip_address | Specifies the IP address of the server to delete from the database. |
| all | Specifes deleting all servers from the database. |
N/A.
N/A.
The following example deletes a server at location 1.1.1.2 from database "database1":
# configure database database1 delete server 1.1.1.2
This command was first available in ExtremeXOS 31.1 as a demonstration feature.
This command is fully supported in ExtremeXOS 31.2.
